Anoying exhaust noise
Civic Jim
12-27-2002, 06:42 AM
My D16A9 has made the most anoying noise since I have had it I am just posting this to see if its my exhaust system or if anyone else has the same problem
at about 2000 - 3000 revs it makes a noise like its blowing at the manifold and it sounds really tinny, I had the standard exhaust on it when I bought it and sounded the same and when I changed the back box it still does it.
I have checked all of the joins and none of them are blowing on tick over,
is this common on civics and if you can, how can you stop it
Cheerz:smoker:
Cheerz:smoker:
91civicDXdude
12-27-2002, 12:14 PM
the only annoying noise i can think off for exhausts would be the exhaust manifold heat shield or catalytic converter heat shield rattle. that is very annoying.
other than that, all i can think of is an exhaust leak. Maybe your exhaust manifold gasket or donut gasket is bad. the engine will make a "ticking" noise and the engine compartment might smell like emissions a little bit more.
sorry im not much help :confused:
kris
12-27-2002, 06:13 PM
Originally posted by civic 16valver
My B16 has made the most anoying noise since I have had it I am just posting this to see if its my exhaust system or if anyone else has the same problem
Cheerz:smoker:
I think I know what you're talking about. My car had a similar sound. Kind of like noise is resonating throught a tin can. Want to know how I fixed it? Get a louder muffler. :D
Seriously though, I'm not sure why it does it.
Cheerz:smoker:
gunnmen01
12-27-2002, 09:49 PM
look underneath it and tap on the heat shields around the converter and the b pipe (pipe behind the converter)...sounds like one of them has rusted loose somewhere...hope this helps...
gunnmen01
gunnmen01
Civic Jim
12-28-2002, 01:20 PM
OK cheerz it seems to get worse with the more people i have in the car so I think it maybe a rear mount or join somewhere i'll have to take a look at the weekend:mad:
Cheerz for da help
Cheerz for da help
