Subaru Impreza WRC (99) Progress
RX7FD
12-22-2002, 11:36 PM
I just started my Monte Carlo Subaru Impreza WRC here are some pics.
http://files.automotiveforums.com/uploads/291504Brakes.jpg
http://files.automotiveforums.com/uploads/517216Engine.jpg
http://files.automotiveforums.com/uploads/419538Front-Brake.jpg
http://files.automotiveforums.com/uploads/378618Undercarrage-2.jpg
Sorry for the quality of the pictures.
Hiroboy
12-23-2002, 02:51 AM
Looking good, I should start mine sometime over the holidays
Steve
Steve
Bobj
12-23-2002, 04:31 AM
Looks good , just started this car myself I look forward to seeing your pictures of the build.:cool:
RX7FD
12-23-2002, 02:27 PM
I just sprayed the bottom and I dont know why but after i priemd the blue body white and sprayed it blue again the sharp corners are still white, should i spray another coat or what??
http://files.automotiveforums.com/uploads/806255Bottom-1.jpg
http://files.automotiveforums.com/uploads/396125Bottom-2.jpg
freakray
12-23-2002, 03:01 PM
How many coats of paint do you have on there?
It took me 3 coats to cover the underside after I primed it.
Remember, you are not meant to cover completely with the first or second coats.....
Ray
Ray
RX7FD
12-23-2002, 03:16 PM
i only have one and it looks way too thick, i sanded down the white areas and im gonna give it another coat but i am afraid it will be too thick.
ales
12-23-2002, 03:19 PM
Too much paint. You should go with mist coats the first couple of times, then add a heavier one. Probably will be enough for the underside.
Good luck.
Good luck.
Guido
12-23-2002, 06:56 PM
Was that painted with Airbrush or spraycan, I guess spraycan. In that case like Ales said probably too much paint.
Maybe you can drybrush the brake discs a bit aith aluminium to highlight the details.
RX7FD
12-23-2002, 07:07 PM
yea that was painted with a spray can, i sanded down most of it today and repainted it it looks better now, thanks for the tips everyone. And what is drybrushing????
RX7FD
12-24-2002, 12:50 AM
I have completed the bottom of the car with the exception of the exaust and the skid plate over the rear axle.
http://files.automotiveforums.com/uploads/582077Bottom-Front.jpg
http://files.automotiveforums.com/uploads/214969Bottom-Rear.jpg
primera man
12-24-2002, 01:48 AM
Starting to look good.....goodluck with the rest of the build
RX7FD
12-25-2002, 07:07 PM
I messed up:mad: I painted the body and it had really bad orange peel, so I wetsanded it and when I reapainted it it still has orange peel but not as much, It looks decent although I am not satisfied I am worried about putting compound on it because i am out of paint and dont feel like buying a 3rd can and I dont have any paint left to paint it again if the compound takes the paint off the edges. I tried compound on one part of the car and then tamiya wax and it had absolutely no effect so now i am deciding whether or not to use compound again or leave it as is, here are the pics:
http://files.automotiveforums.com/uploads/433150Body1.jpg
http://files.automotiveforums.com/uploads/704137Body2.jpg
http://files.automotiveforums.com/uploads/353760Body3.jpg
http://files.automotiveforums.com/uploads/304830Body4.jpg
