"Accessory" fuses (not hot) in 2001 Alero?
tmyate01
12-21-2007, 11:04 PM
Does anyone know what the "accessory" fuses are in a 2001 Alero? In other words, I'm looking for the fuses in the fuse panel that are only hot when the key is inserted into the ignition and the key is turned to the "acc" position. I'm hardwiring a radar detector and gps device to my fuse panel. Instead of trial and error, I just wanted to know if anyone has taken the time to make a list of these fuses.
Thanks,
Todd
Thanks,
Todd
nqc2k
12-22-2007, 10:54 AM
I'd use the radio fuse
xeroinfinity
12-22-2007, 06:33 PM
Easiest place to harrd wire would be to the lighter hot wire.
As far as hooking it to any fuses with those puggy back attachments, just pick something that's only hot when the keys on and something not used regularly when these additional components are running.
Drivers side fuse box, B, C, pass side FB, H or I.
Also here is a link to a wire diagrams for your Olds. :bigthumb:
http://www.the12volt.com/installbay/vehiclewiring/1/yeard/Olds.html
tmyate01
12-28-2007, 12:24 PM
Thanks for the help xeroinfinity. That was exactly what I was hoping for.
