350 s10
lkickinwing87
12-18-2007, 08:38 PM
how do i put a 350 in my 2001 s10? is it possible?
ZL1power69
12-19-2007, 09:32 AM
yes it is possible but it depends on what V8 you want to use as to how difficult its going to be. what did this engine come out of? Most SBC swaps require new V8 motor mounts, V8 swap headers, and wiring harness modifications. you will also need to eiter reflash your stock ecu or replace it with the V8 ECU (if you plan to use electronic fuel injection). If your S10 is an automatic, the stock 4L60E should bolt up to the 350 (again depending on what SBC you have) but i would strongly suggest a performance rebuild as they are not exactly "bullet proof".
