92 lasabre question
aww1
12-15-2007, 07:07 PM
im installing an amp in my 92 lasabre and cant find a hole in the firewall to run the power wire through can anyone help me?
spinne1
12-16-2007, 03:53 PM
There are no open holes. The "holes" are packed with rubber and wires or linkage. The only way to get a wire through is to either force a small wire through the area where wires go through now (or the transmission linkage, or throttle linkage), or drill a new hole. Doing so is not something you should take lightly as you could mess things up if done in the wrong spot. The best way would probably be to remove your glove box and also the shield below the passenger side feet and look for a clear space on the firewall. Then check the other side to make sure it would be an unobstructed place for a hole. After the hole is done you need to somehow protect the wire(s) going through the hole against being cut by the sharp metal of the hole. I'm sure products are made for that purpose. Google it.
