2001 ford taurus DOHC Heat
Rschrei518
12-15-2007, 12:12 PM
Since the winter started i am getting no heat it blows cold. Car is not running cold or hot and is warming up properly so i do not think it is the thermostat overflow is full with antifreeze so what else could be causing heater to blow cold. Sometimes if i drive for a while and let heat build up i will get heat for maybe 1 minute but then blows cold again any thoughts?
TaurusKing
12-15-2007, 02:11 PM
Could be a blend door issue, also if you have the eatc system, check the thread recently about resetting the control head, for some of those it did the trick..
shorod
12-15-2007, 03:15 PM
You may also want to review the threads on water pump vanes and backflushing the heater core.
-Rod
-Rod
