95 jimmy 4.3 front brake hose
grace05mam
12-13-2007, 08:39 PM
The front brake hose is leaking on the passanger side. How do we remove the old hose without mesing up anything and causing a bigger problem? It is really rusty and looks funky under there. I need some advise before we start so I don't do this :banghead: . P.S Sorry Grand Master couldn't find where to post new thread, still a :newbie:
old_master
12-13-2007, 09:22 PM
Rusty brake lines are always a challenge! Soak it with a product called PB Blaster. Available at most auto parts stores. Soak it some more, then soak it some more and hope for the best ;) If the steel line twists off, you'll end up replacing it. If the vehicle has ABS, DO NOT allow the master cylinder to run dry.
