broken cam
pbrizzle86
12-07-2007, 11:22 AM
hey i just tried to fire up my mini me swap for the first time and i discovered i have a broken camshaft. will the zc cam work in the y8 head or do i got to get one specifically for the y8. thanks paul
FrodoGT
12-07-2007, 03:07 PM
Itll work, but the timing is going to be off and the engine will run differently.
maxassassin
12-07-2007, 04:28 PM
ive got a z6 cam lay around from a mini me swap i thought about doing. but then i decided to make some numbers with a no vtec a6.
pbrizzle86
12-07-2007, 06:39 PM
is there other cams i can use in this head to get it to run normal im having a hard time finding another y8 cam. the ones i have found have been whole cylider heads. so if anybody has one they would like to part with let me know.
FrodoGT
12-07-2007, 07:47 PM
You could always get a new cam and make more power..
maxassassin
12-08-2007, 01:21 AM
you could try to find regrinds as well if you dont mind any of that kind of stuff. alittle extra spunk. i suppose. the z6 came is fairly close. im guessing since its a sohc vtec cam.
pbrizzle86
12-11-2007, 04:15 PM
ok so i got another head cause it was cheaper to get the whole head than just the cam. its a good thing too cause we took that broken cam head apart and the bearings were just toast it was so bad i dont think having it machined would have brought it back.(for any reasonable amount of money anyways) but i have a question about timing the mini me. do i time it to the spec of the car i got te head off of or do i time it for the 1990 spec. does it depend on the computer you use or the head. i would guess the head but im not sure. but if you need to know im running a chipped pm6 for now untill i convert to obd1 to run the vtec right.And the head is a y8. if you have any answers or suggetions let me know. thanks again Paul
FrodoGT
12-11-2007, 06:18 PM
To the cam, or in your case the head.
