1988 Chevy k1500 missing/sluggish
rtc1139
12-03-2007, 10:04 PM
Hi. I need some advice. I have a 1988 Chevy K1500 with a 350 and TBI. My truck starts great and idols like a dream. When I try to drive it or get higher RPM the truck tends to miss and backfire if you floor it when it starts to miss. The engine never dies. This causes the truck to shutter. I have tried the following: new plugs, wires, ECM, cap, rotor, oxygen sensor, knock sensor, battery, fuel pump, fuel filter, and ignition module.
Please help as I am running out of money and time....
Thank you in advance.
J-Ri
12-04-2007, 03:28 PM
Check the exhaust backpressure. Sounds like possibly a plugged cat.
ridebetr
01-21-2008, 08:18 PM
Did you fix the problem? I'm having the same problem.
G.A.S.
01-21-2008, 08:24 PM
I would like to know the cure as well
j cAT
01-22-2008, 12:13 PM
take out the o2 sensor and run it with the o2 hole open if it runs better the cats or exhaust are plugged.....
