Drain petcock
pdreher
12-01-2007, 09:36 PM
What is the easiest way to remove the drain pet cock out of a 2000 bravada? and is there a special tool to use?
old_master
12-01-2007, 09:59 PM
No special tool, just unscrew it. It will not come all the way out. When it stops unthreading, just pull straight out. It will move outward about one half inch.
pdreher
12-01-2007, 10:05 PM
it does not look like there is any way to unscrew mine if it had a tap on it, it is broke off now how esle could i un screw it? and suggestions?
old_master
12-01-2007, 10:28 PM
Here is a link that shows the plug: http://www.partsamerica.com/ProductDetail.aspx?MfrCode=RNB&MfrPartNumber=61133
You might need to remove the black plastic shield that covers the oil filter area so you can access it better. There are about 6 15mm bolts that hold the shield on. Hope this helps.
