Durango ABS and brake lights
Cvolpe
11-29-2007, 03:39 PM
I have 99 Durango with 97K miles on it. Once in a while while driving the ABS and Brake light come on the dash. If I stop and turn the car off and restart the lights go out. Is this a bad sensor, bad brakes or something else. Anybody else has seen this condition?
Thanks
Thanks
wayneo69
11-29-2007, 07:32 PM
check the brake fluid make sure it is ok if it is now im just guessing with out pulling code it may be a the rear speed sensor
cenrobertgilbert
11-30-2007, 12:56 PM
if its got brake fluid u probly have a bad sensor. the same thing is happenening to my car
Cvolpe
12-04-2007, 04:08 PM
Thanks guys. It turned out to be a rear wheel speed sensor. It only cost me 184.00:) to fix it. A deal compared to what things cost today.
dirtdriver11
01-05-2008, 07:59 PM
mine does the same thing, and I 've already relaced the sensor once. Any ideas?
wayneo69
01-05-2008, 08:40 PM
pull some codes out of it and go from there
dirtdriver11
01-05-2008, 08:54 PM
i can't get any codes out of it for the brake lights
wayneo69
01-05-2008, 09:17 PM
are you saying your brakelites are not working or the brake lite in the dash is on
Benzman
01-07-2008, 07:49 AM
The codes for the ABS system requires a special reader. Autozone and those kind of places don't have it.
They are very expensive.
I have the same problem, after replacing the front and rear wheel sensors and not curing the problem, I just kind of gave up at least for a while.
