97 Accord turn/no start
GregariousLoner
11-26-2007, 03:47 PM
I've got a 97 accord (4-cylinder non-VTEC) that will turn over, but not start. The battery is good, and the terminals are adequate. There's oil on the #3 spark plug, but other than that all four are in good condition. As a test, we unplugged the #4 spark plug sleeve and checked it for a spark while trying to start the engine and found none. The air filter, while dirty, is also adequate. I would just like to know anyone's thoughts before I start taking this thing apart. Thanks!
somick
11-26-2007, 05:00 PM
You did not mention fuses. Did you check them.
The next step would be to go after the ignition coil I think.
Good luck,
Sam
Good luck,
Sam
GregariousLoner
11-26-2007, 05:13 PM
Good luck,
Sam
Sam, Thanks. The fuses are good. The ignition coil came to mind, but I don't know how to check it, or what exactly I should be looking for.
Good luck,
Sam
somick
11-26-2007, 08:31 PM
The testing procedure should be in the repair manual.
I think you will find a link to a free manuals at the top of this forum in the sticky.
Good luck,
Sam
Good luck,
Sam
somick
11-26-2007, 08:33 PM
GregariousLoner
11-26-2007, 09:51 PM
Good luck,
Sam
Thanks for your help. I'll let you know what I find if it's anything useful.
Good luck,
Sam
