Fast Idle Speed Warm or Cold Start
Michelg777
11-26-2007, 02:22 PM
I have a 2001 Montana 3.4L with 66K miles. After the van sits overnight the inital start has a large gas surge causing very high RPM. Sometimes the starter has dificulty breaking away from the fly wheel, hence that terible grinding sound. I am not touching the gas during start up. The engine will idle at around 1900 RPM for 6 to 8 minutes followed by 1200 for another 5 mimutes then normal. I cleaned the mass air sensor and changed the coolent temp sensor. I cleaned and lubricated all the linkages. There are no error codes. Any ideas what to look at next. :screwy:
LMP
11-27-2007, 12:15 PM
This has been reported a lot of times. It has been alleged in several instances that leaking upper intake manifold gasket would cause that....but I have never seen those who had complained come back and confirm or deny it solved their condition....
My son's '92 Z-34 :shakehead suffers the same problem....checked the Idle Air Control motor to no avail...I plan to fool the computer make it believe the engine is already warmed up..like i did on my Transport for different reason though.
Michelg777
11-29-2007, 01:28 PM
You mentioned the the idle motor. I checked it... it was gummed up. I cleaned the seat and the bore. No more high surge start-ups. The start-up RPM dropped to 1250. Thanks for your help!
:popcorn: Miller Time
rockwood84
01-20-2008, 08:49 PM
the iac and tps will do this also dirty throttle plate
