4x4 light on and off
tritonboat186
11-25-2007, 05:52 PM
2001 4 x4 service light comes on and off as you drive down the road and all 4 of the button lights come on too when the service light is on.you here the clicking noise under the dash like the motor is trying to shift the transfer case . no check engine light is on.anyone had this problem thanks terry:screwy:
tritonboat186
11-30-2007, 01:43 AM
[quote=tritonboat186]2001 4 x4 service light comes on and off as you drive down the road and all 4 of the button lights come on too when the service light is on.you here the clicking noise under the dash like the motor is trying to shift the transfer case . no check engine light is on.anyone had this problem the other problems are that the trans don't shift down the motor bogs down like i am running out of gas abs light comes on and cruise doesn't work all this happens all at the same time there are no code in the 4x4.is the start switch bad in this 2001.:screwy: thanks terry
MT-2500
11-30-2007, 10:01 AM
Get it on a good engine/transmission/transfer case/and ABS capable scanner and get codes.
Watch and check the speed sensors real close.
ABS or speed sensor problem will disable 4 Wheel
Post back code no.
And we caqn help.
MT
Post back code no.
And we caqn help.
MT
tritonboat186
12-03-2007, 09:22 PM
i have already checked there are no codes in it.
MT-2500
12-04-2007, 09:40 AM
233 0r 236 transfer case?
How and what kind of a scanner did you use to check for codes.
236 will store codes if there is a problem?
Is the scanner showing anything on transfer case operation or data?
Will it run the shifting test?
tritonboat186
12-18-2007, 10:18 PM
it has all the problems when it rains .we have boiled it down to the box that makes it shift the computes quit talking to each other in the rain other day.next day it worked find.going to change the shift box.
MT-2500
12-19-2007, 10:53 AM
If you are refering to the encoder shift motor.
Some of them can be repaired.
Some have a cracked case that lets water in and burns up resisters.
Good luck
MT
Good luck
MT
