Brake rotors and pads
Ridge_Roamer
11-24-2007, 10:51 AM
Ga'Day all: I had my vehicle in for a safety inspection and was told three of four rotors are bad and are destroying the pads. They all appear to be disintegrating as if a batch of rotors were cast with a material defect. These OEM parts have only 11K on them. Would like to know if anyone has experienced similar problems.
MagicRat
11-25-2007, 09:33 PM
I have only heard of this when rotors have been severely overheated which leads to cracking.
Unless you drive down a mountain towing a huge trailer its difficult to overheat brakes like this.................. unless your calipers are not retracting fully and allowing the pads to drag.
CraigFL
11-26-2007, 06:43 AM
It would be helpful to know what year, make & model as well as if the safety inspection place offered to fix your problem and for how much.
Ridge_Roamer
11-27-2007, 07:00 AM
Thanks for your reply. I intentionally omitted the vehicle info because the problem may not be specific to one manufacture and the dealership I went to (only to inspect the brakes after failure) was to document the problem. The NHTSB has many similar claims of failure. I am in touch with a Mfg's rep. and have filed a claim with them of which I will post the outcome.
Thanks again.
Thanks again.
