Grand Am GT 2003 Heat Problem
jason_brier
11-23-2007, 12:34 PM
Hello All, I have a Grand Am GT 2003 with a problem...My heater only works when the dial is turned all the way to the right (hottest setting). When the dial is pushed up even a bit, the air goes from hot to cold instantly. There's no in between like there used to be when I bought it. I have no idea what it could be, but my girlfriend thinks it's the thermostat.
J-Ri
11-23-2007, 02:43 PM
It's definately not the thermostat.
Check the temperature switch to make sure it's not shorted causing everything coolor that hot to be the same. Also and the blend-door actuator.
xeroinfinity
11-23-2007, 02:48 PM
Welcome to AF.
So are you saying your heat isnt hot and your blowers not working only on high ? If the blower isnt blowing on all settings check the fuses and see this thread if they are OK.
http://www.automotiveforums.com/vbulletin/showthread.php?goto=newpost&t=665246
On the temprature, could be the thermostat, could also be the blend door on the hvac unit under the dash, no fun thier a real pita to work on.
If the thermostat was the issue then the temp gauge would read a lower operating temp the usual.
Could also be you have a 185 deg thermostat, and if its realy cold out the heat settings can be cooler then norm.
A complete cooling system flush may even be needed, gonna take some trouble shottin on your part.
hope that helps.
