89 crx brake help.
cmjrbking123
11-18-2007, 07:24 PM
I dont really now how to adjust my rear drum brakes.
are 89 si's self adjusting? am i supposed to stick a screwdriver where the plug in the drum is?. i was told it should turn and have some drag at lest half way is this true?
any help on how to adjust them would be greatly appricated thanks.
FrodoGT
11-18-2007, 08:26 PM
If you do adjust them manually put a very slight drag on them. They are/should be self adjusting. Although they may be so old that they wont adjust.
To do it you simply drive backwards for a few feet as fast as you feel comfortable and jam on the brakes. Do that 2-3 times just to be sure.
Christ
11-19-2007, 01:30 AM
to adjust them manually, yes, stick a flathead in the space where the plug is... chances are, they're stuck/sticking so they don't adjust, or the springs are worn. next time you change your rears, get a new adjuster, or at least that that one apart and clean it, and get a drum kit. (new springs and retainers)
