96 S10 Blazer stuck in 4 wheel drive
96wWindstar180K
11-18-2007, 09:11 AM
Maybe someone can help. 96 S10 Blazer 4.3 litre is stuck in 4 wheel drive high. Pushing the buttons to switch out does nothing. Is there a fuse or maybe aproblem with the switch? Any thoughts? No noise or problems prior i started about 3 days ago. Thanks
___Brandon
11-24-2007, 10:47 AM
I think there is a activation solenoid on the front end that likes to go bad. With yours being push button there is probably also an actuator on the transfer case that may not be working.
DelCoch
11-25-2007, 04:50 AM
When you press the 2Hi button does it light up and the 4Hi light go out? If so, press the 2Hi and then back up to see if it will disengage.
