91S10 Blazer truck won't accelerate in 4x4
adrian91
11-17-2007, 07:10 PM
Hi
I have a 91 Chev S10 Blazer , 4.3 L, 4x4 , automatic transmision , manual shifter, 270 000 km . I bought it last year . In 4h mode the truck doesn't accelerate past 85 km/h .
I checked the fluid in the transfer case and I found out it was overfilled . I drained the fluid to the normal level , but I didn't notice any change .
It shifts easily from 2H to 4H . The 4h light comes on as well as the front axle diagram .
I never tried to put it in 4 low . Can this be the problem ? It actually engages the 4Low mode?
MT-2500
11-18-2007, 09:09 AM
Are you test driving on a dry payment?
Are your tires matched?
MT
MT
DelCoch
11-19-2007, 02:40 AM
Hi
. . . . Can this be the problem ? It actually engages the 4Low mode?
Do you have a tach? If in 4-Low it will be taching about 5K at 85 km/h.
adrian91
11-19-2007, 07:28 PM
Thank you for your answer
Yes I was testing it on dry pavement and it doesn't have a tach.The tires are matched . I'm positive that the engine isn't reving that much . It's just shifting from drive to overdrive at about 80 km/h , like usual and after that , no matter how much I push the pedal it doesn't go faster than 85 km/h. It feels like I push the break in the same time, or I pull a heavy load.Of course if I push the pedal to the floor it shifts in lower gear but , there's a lot of vibration and noise .
MT-2500
11-20-2007, 08:35 AM
4W is not to be used on dry payment.
If it does ok IN 2W AND PULLS DOWN IN 4W that may be normal.
Does it do OK in 2W?
MT
MT
adrian91
11-21-2007, 04:38 PM
Oh yes .
It runs excellent . it goes 140-150 km/h with no problem except one small detail. If I drive 120 on the highway for long time (wich is extremly rare due to the trafic ) when I come to a stop, the oil pressure gauge goes down from 575kpa to 275kpa and up again very quickly .It doesn't light up the red warning light and if I put it in N or P the needle goes back to normal . It only happens in the summer time.
Anyway this is an other problem probably related to the old age of the engine . 270 000 km
It seems like there's nothing wrong with the transfercase.Tomorrow it's gone snow in here and maybe I'm gone use my 4x4 . Thanks a lot
