Changing Spark Plugs
GPcarnut
11-15-2007, 05:11 AM
I have a 2000 gpgt 3.8 do you remove the front mptor mounts to get to the rear spark plugs?
hillre
11-15-2007, 07:56 AM
FYI,
I would suggest going to your local Auto Zone to purchase a Haynes manual for your vehicle. They cost less than $15 bucks I believe. The Haynes manual is very beneficial. It contain step by step instructions and photos on how to make many repairs. Or you can just review the manual to see how the repair should be made. On my 1996 Grand Prix (3.1L) I had to disconnect the upper motor mounts and afterwards, insert one of the mounting bolts in the support brackets so I could rotate the engine forward after putting the transmission in neutral. Also, had to disconnect air filter housing or whatever it's referred to as from the throttle body prior to rotating the engine. I'm not sure if the 3.8 has the same setup. I had to put a couple of pieces of two-by-four behind my engine to keep it rotated while I removed the plugs. I'm a amateur but I got the job done. Saved myself over $100 by not taking to local ripoff shop. Hope this helps! Take Care!
eL_bEyAcO
11-18-2007, 04:04 PM
does anybody know of any picture guided websites or links on how to replace spark plugs on a pontiac grand prix gt 3800 '02 ???
eL_bEyAcO
11-18-2007, 04:05 PM
send websites or links to [email protected], on how to replace spark plugs on a '02 pontiac grand prix gt 3800
eL_bEyAcO
11-18-2007, 04:08 PM
i also have another problem with this same pontiac, it has a hard time starting up, i know its not the starter or the battery, just replaced them both. when it finally starts up it has a hard time taking off, also any body know anything about that ?
eL_bEyAcO
11-18-2007, 04:15 PM
When i press the gas all the way down it takes off very slowly.....
BNaylor
11-19-2007, 07:10 AM
Does it feel like you are in a higher gear during take off? What other symptoms? Any SES/CEL light? Check the TCC fuse to make sure it is not blown.
eL_bEyAcO
11-19-2007, 05:15 PM
yeah it feels exactly like you say, like on a higher shift, also has trouble starting up like gas has trouble going through, only the rpm goes up
eL_bEyAcO
11-19-2007, 05:26 PM
do you think its the spark splugs, cuz if it was the fuel pump it wouldnt start up at all. right ???? it would try but it wouldnt catch the gas . right ???
BNaylor
11-19-2007, 05:56 PM
It depends because the fuel pressure may be low. To rule out the fuel pump and associated components like the relays and fuel filter you'll need to check fuel pressure at the fuel injector rail to see if it is in specs. 48-55 psi.
In neutral and when you do get the engine started how it it? Is the idle good and when revving do you feel any misfiring?
eL_bEyAcO
11-21-2007, 06:57 PM
i am more than sure it is the fuel pump, cuz when i finally get the car started, it smells alot like gasoline, and its loosing powere more often, today it finally turned on, but then turnd off again and did not turn on anymore. im certain its the fuel pump now, took it in, lol, but thanks anyways for your advise BNaylor !!!! cool
eL_bEyAcO
11-21-2007, 06:58 PM
do you know wat part i can replace or upgrade, so it can do like lets say 0-60 in like 5 secs ??, also so it can give a better performance....
eL_bEyAcO
11-21-2007, 06:59 PM
or any recommended high performance parts at all ??
eL_bEyAcO
11-21-2007, 07:00 PM
is it possiblwe to cut a curve off from the springs in order to drop it ?
tblake
11-21-2007, 11:45 PM
check www.zzperformance.com for performamce parts. they have a few for the NA 3800
eL_bEyAcO
11-24-2007, 06:07 PM
got it fixed already, fuckin fuel pump was worn out already, gtp is supercharging at its fullest once again.......thanks alot everybody
