01 caravan fuel gauge fluxuates
Turbokid15
11-14-2007, 05:15 PM
Whenever you drive the fuel gauge will go up an back down occaisionaly. Last time it showed it was on 1/4 tank but it only took 5 gallons. Could the float on the fuel pump be bad.
Bear
11-14-2007, 07:25 PM
The sending unit (float) can cause this problem it did on my '96 and as the sending unit is in fuel tank and attached to the fuel pump, I replaced the complete fuel pump module (did not wish to do this twice if fuel pump went south). If mechanically inclined, you can do this, I did on my garage floor using jack stands and a floor jack.
