AIR DRIED BEEF DOG FOOD
FS 99 Civic Hatchback B18A1 $4600 OBO Clean Title
Willb2305
11-09-2007, 06:46 PM
1999 Civic B18A1 $4600 OBO
Clean Title
Palmdale, CA
Vin Number 2HGEJ6345XH111669
Serious buyers only if you dont have the money or plan on sending fraud or fake checks dont bother your wasting your time. I prefer Western Union or Money Gram which is inside Walmart. but if you send cashier's check or ceritifed check it must be sent out via USPS Express Mail which is overnight service.
This is a silver color 99 Civic Hatchback with a b18a1 motor. Tein Full Coilover Suspension with Pillowball upper mounts ride height adjustable retails for $1600 alone. Will need a new head, distributor, transmission and radiator. It had a gsr head in it, but needs a new one. I have included the aluminum valve cover for the head. Has a stainless steel oil line that went straight into the head for a stronger vtec. Blox Intake Manifold, Skunk2 OverBored Throttle Body. Cold Air Intake, 4-1 Stainless Steel Headers, 2.5inch pipping with Wicked Flow Exhaust. The motor should have around 45 to 60k miles on it not exactly sure. Has a 5 inch tech in it with a bright shift light. Aftermarket steering wheel with Momo Hub Adapter and Quick Release. Has the Red Honda Emblem on the steering wheel. tires have about 85% tread left on them. has acura gsr stock rims on it. Upper Front Strut Bar Rear Upper Strut Bar. Has Hasport Rear Motor Mount. Replaced the Driver Side Motor Mount about 3k miles ago. The upper driver and passenger side motor mounts have prothane motor mount inserts in them. Has Skunk2 GSR ECU with 10,000 RPM redline. This ecu is meant for camshafts on the gsr head which it did have. Has a fuel pressure regulator. Great light weight car for any motor swap. I have the stock steering wheel which will be included with the car and a Black Type R Front Grill. Broadway mirror also included. Has Red Honda Emblems on outside of car, JDM sidemarkers. clean inside of car. Has Kenwood KFC-W3002 sub 500 watts peak power and 2 alpine amps. 1 Alpine amp is a 2 channel 500 watt amp MRV-T500 model. and a Alpine 4 channel 250 watt MRV-F250 model. Has a Legacy Blue Diamond 2.4 Farad Digital Cap for the sound system. Tweeters are up high on the pillars inside the car for a clean sound. Email me at [email protected] for questions on the car im selling it for a friend and know alot more about the car and parts then the parents do. Call Vickie at 661-400-1868 if you want to take a look at the car, only call if your serious about buying the car.
http://i10.photobucket.com/albums/a117/Willb2105/IMG_0240.jpg
http://i10.photobucket.com/albums/a117/Willb2105/IMG_0241.jpg
http://i10.photobucket.com/albums/a117/Willb2105/IMG_0242.jpg
http://i10.photobucket.com/albums/a117/Willb2105/IMG_0243.jpg
http://i10.photobucket.com/albums/a117/Willb2105/IMG_0244.jpg
http://i10.photobucket.com/albums/a117/Willb2105/IMG_0245.jpg
http://i10.photobucket.com/albums/a117/Willb2105/IMG_0246.jpg
http://i10.photobucket.com/albums/a117/Willb2105/IMG_0247.jpg
http://i10.photobucket.com/albums/a117/Willb2105/IMG_0248.jpg
http://i10.photobucket.com/albums/a117/Willb2105/IMG_0249.jpg
http://i10.photobucket.com/albums/a117/Willb2105/IMG_0250.jpg
http://i10.photobucket.com/albums/a117/Willb2105/IMG_0251.jpg
http://i10.photobucket.com/albums/a117/Willb2105/IMG_0252.jpg
http://i10.photobucket.com/albums/a117/Willb2105/IMG_0253.jpg
http://i10.photobucket.com/albums/a117/Willb2105/IMG_0255.jpg
http://i10.photobucket.com/albums/a117/Willb2105/IMG_0256.jpg
http://i10.photobucket.com/albums/a117/Willb2105/IMG_0257.jpg
http://i10.photobucket.com/albums/a117/Willb2105/IMG_0258.jpg
http://i10.photobucket.com/albums/a117/Willb2105/IMG_0259.jpg
http://i10.photobucket.com/albums/a117/Willb2105/IMG_0263.jpg
http://i10.photobucket.com/albums/a117/Willb2105/IMG_0273.jpg
http://i10.photobucket.com/albums/a117/Willb2105/IMG_0277.jpg
http://i10.photobucket.com/albums/a117/Willb2105/IMG_0282.jpg
http://i10.photobucket.com/albums/a117/Willb2105/IMG_0284.jpg
