AIR DRIED BEEF DOG FOOD
1997 Plymouth Voyager strange drain pipe on firewall?
Krazy Jeff
11-01-2007, 01:24 PM
Sorry for all the recent questions and new threads.. like I said before, I just got this vehicle, and I am slowly learning what's underneath the engine and also difficult when you don't have a owner's manual.
I notice a wet spot underneath the van (on the pavement). I opened the hood and found exactly the spot where the wet spot is being caused by. Its coming from a strange open pipe sticking out on the passenger side on the firewall, behind and close to the first spark plug (I provided pictures below to ishow where this pipe is and also a close up in two different angles).
Can you guys tell me if this pipe should be exposed this way? Is this normal? Thanks in advance.
http://img140.imageshack.us/img140/4766/engineviewpipe.jpg
http://img268.imageshack.us/img268/1057/110107021.jpg
http://img683.imageshack.us/img683/1498/110107022.jpg
cbwilsha
11-01-2007, 07:31 PM
Yes, this is normal. It is the A/C condensate drain and is where your also normal puddle of water comes from. You're in trouble when the A/C is on and you don't get the puddle underneath.
C.B.
Krazy Jeff
11-01-2007, 07:56 PM
Thanks. I appreciate the reply.
I think Plymouth probably didn't choose the correct place for that drain pipe. Because I see that where the pipe is positioned it is above some other metal that it's underneath it. Rust is an issue with metal.
peterjon1
11-02-2007, 09:40 PM
You could put an elbow and extension on it to direct the water where you want it.
Krazy Jeff
11-02-2007, 10:34 PM
Excellent idea. Thanks.
