Amp impedence
Galuple
10-28-2007, 11:54 PM
So I just got myself a 4 channel amp and i'm planning on using it to wire my 4 speakers i have in my civic. my question is if i have a pair of 2 ohm jbl speakers and a pair of 4 ohm rockfords what impedence will the amp end up seeing? does it really matter if i mix them or not?
pimprolla112
10-29-2007, 12:04 AM
What amp, most good 4 channel amps have 2 power supplies while cheaper ones only have one. Depending on the amp it shoudlnt be a problem. Also make sure your 2 ohm speakers can handle the higher power since the impendance will be lower.
PaulD
10-30-2007, 04:50 PM
you have 4 speakers and 4 channels ...... each channel will see the load of the speaker attched to it.
