Power Steering Leak !!
spongebritt8
10-22-2007, 10:34 PM
I have a 95 4runner with a 3VZ-E. After cleanup, traced leak back to the power steering vane pump and it looks like the source is the rear housing at the snap ring and the underside of the vane pump when looking up frop under the passenger front wheel. All pressure and return lines look fine. Can leak be the o-ring between oil reservoir and the pump body? or internal to the pump? Does this call for simply replacing the pump? Any ideas??? Thanks.
vandok13
10-25-2007, 07:01 AM
Have you figured it out because i might be able to help. Its common for the oring between the reservoir and the pump to go bad. There are three screws that hold that part on. AdvanceAutoParts have orings in stock, it's a cheap and easy fix. If worse comes to worse, you can buy a rebuilt kit for the entire pump and rebuilt the whole thing. I would try the single oring fix first though. Also, make sure the VSV isn't leaking up through the vacuum lines to the intake.
spongebritt8
10-25-2007, 05:05 PM
Thank you vandok13, I have not tried anything, was waiting for the weekend and an experienced suggestion. I will try this Saturday and reply if successful. Thanks again for the input!!
vandok13
10-27-2007, 08:46 PM
Any Progress?
spongebritt8
10-29-2007, 10:35 PM
Did the o-ring and it was pretty easy (unfortunately it was raining all day) and sorry to say that was not the culprit. I still see a bit of fluid at the bottom of the PS Vane pump assy around the rear snap ring so that may be the source.
