91 Civic Dx Manual 5 Speed...What motor can I swap ??
BiggWaukegan
10-17-2007, 02:37 PM
I have a d15b2 motor in my 91. its zippy but I think i want more hp. what motors easily swap with this one. my local scrapyard has quite a few honda motor ready to be pulled thanks.:grinyes:
civic lover
10-17-2007, 03:13 PM
kind of a vague questions. how much money you looking to spend? what are the hp numbers you looking for?
Tony
10-17-2007, 06:25 PM
Not really vague, just depends how much work you want to do. The easiest would be an A6 swap from an Si. Just requires the MPFI swap(which any swap needs). Then you could do a Z6 or y8 which would either require a OBD0-OBD1 conversion harness or an A6 ECU and distributor and something to kick the VTEC in.
once again, I will point you in the same direction I point a lot of new people, no searching for the right post, ill give it to you
http://www.automotiveforums.com/vbulletin/showpost.php?p=2673547&postcount=27
Enjoy
Enjoy
Christ
10-18-2007, 01:56 AM
instead of swapping the whole head, for the A6 part, you can swap just the cam. it's alot easier, then do the MPFI swap, and it's the same thing as having the A6 head swap... I dont recommend the head swap unless you're already doing something inside the engine.. other than the cam, there is just about nothing different between the A6 and the B2 engine.
Tony
10-18-2007, 03:57 AM
Drop, are you going crazy? No one said anything about swapping the heads out :)
He said engine swaps, A6 is by far the easiest, and if you take your route to it, its even easier :)
BLU CIVIC
10-18-2007, 05:26 PM
i say pick any motor and go for it
Christ
10-19-2007, 01:37 AM
yeah, I don't know what the hell has been wrong w/ me... been beat all week...
Anyway, it's valuable info if you don't wanna do a complete swap, so take it to mind.
Either way, MPFI is definitely needed for anything, if you plan on making more than 100 HP. I mean seriously, whoever thought of DPFI needs to be shot.
