doors lock when car is put in gear
emilys granpaw
10-16-2007, 08:09 PM
Hi . I was wondering if anyone may be able to help find out why my doors don't lock when car is put into gear( WITH ENGINE RUNNING)
mitch1987
10-16-2007, 08:18 PM
Check in your user's manuel if you have it, in a lot of cars its an option you can enable or dissable.
Loekee75
10-16-2007, 09:53 PM
what year is the car? The automatic lock feature was an option that didn't come around until '94 or '95, I believe. It wasn't always a standard feature.
emilys granpaw
10-18-2007, 10:12 PM
Hi again. The year of my car is a 95. I have also noticed, that if I start the car with remote starter, the doors will lock when it is put into gear. Hope this will help with the suggestions. Also I do not have the manual for the vechicle. Thanks a lot for your help and insight.:) :)
Loekee75
10-19-2007, 02:02 AM
If you've got a remote starter, then that's a whole other control module that is activating the locks when the ignition is started. I've got an aftermarket keyless entry system that engages the locks when the switch is turned to run, and unlocks the the locks when the car is switched off (otherwise my car, without the aftermarket keyless entry system, will not automatically engage the power locks as it was not originally equipped to do so). That must be the case with your vehicle. The remote starter system came equipped with the auto-lock feature, but the vehicle itself may not have the same feature. If your car is supposed to have the auto-lock feature, I'd suspect a faulty PNP (Park/ Neutral Position) switch/ circuit.
