automatic headlights
cookiedude87
10-09-2007, 09:06 AM
I was driving home from work when i noticed my lights were on so i turned them off and the display says headlamps suggested.... so im thinking there is something wrong with my automatic headlights... anyone have any ideas on the problem and cost of fixing it??
cookiedude87
10-09-2007, 09:07 AM
I have an 04 grand prix btw!! srry bout that
tblake
10-09-2007, 10:46 AM
could be a problem with your sunlight sensor. NOt sure where its locate on a 2004, but make sure your dash is clean and that sunlight can reach it.
cookiedude87
10-09-2007, 04:05 PM
the dash is clean and nothin is blockin the sensor....
tblake
10-10-2007, 01:16 AM
well, then price out a sensor. Is it easy to remove? It sounds like the sensor is faulty or the wiring too it. You might want to test the sensor with an ohmmeter in direct sunlight versus dark. See if the resistance changes. If it doesnt, replace the sensor. I will see if I can find you a wiring diagram in the morning. Too late to look now!
