Help with sway bar
Belldandy
11-27-2002, 12:17 AM
Hi I brought a used 94 integra rear sway bar off ebay. If I remeber correctly the civic and integra share some same chasis stuff. The sway bar will fit my civic right? it's also like 14mm is that like good enough? it is a jdm stock one but that should be good enough.
gunnmen01
11-27-2002, 09:22 PM
You'll need the mounting brackets and the lower control arms that have the mounting stud on them also...
gunnmen01
Belldandy
11-28-2002, 01:26 AM
It comes with the brackets and such. Mounting studs????
gunnmen01
11-28-2002, 08:56 PM
where the sway bar mounts on the lower control arms
Belldandy
11-30-2002, 11:47 AM
Oh. Heh oh well I'll wait for it to come and see what happens. It'll probably fit up fine since my year was made in the same with the si's and hopefully it has the holes nad such.
