99 ford ranger 4x4 pulse vacuum hubs
james1978
09-28-2007, 06:23 PM
:banghead: I brought my truck to a dealer and they ran a diagnostic and found the vacuum solenoids were leaking. no problem so i thought, until the warranty company said it is not covered so now, i need help with finding where i can get the solenoids and where are they located on my truck. bye the way they some how control the 4x4. any help will be appreciated thanks.runaround
82Stang
10-14-2007, 10:10 PM
What did the dealer say you needed? Was it front hubs? If so, then there are o-rings and etc in there that control the 4 wheel drive. My 99 Ranger is this way and there is no way around getting hubs if needed. They are very expensive......$250+.
bigryan84
12-11-2007, 05:08 PM
i had the same problem.. try to manuall lock them in.... get a suckson pump ( the one that does not let the air out when you release it) take a part the hubs and push them down until they are lock in... MAKE SURE YOU DONT LOSE THE SUCKSON OR IT WELL NOT WORK....
TeamExploder
12-12-2007, 09:11 PM
Pretty sure you could convert your truck to manual hubs, but they're a pain in the ass unless you leave them locked in all the time then your chewin down your gas mileage.
UVM11
12-13-2007, 03:45 PM
there is a way to conver the stock hubs to manual lockers by a push button type way, there are step by step directions on how to do it at this website:
http://www.ford-trucks.com/article/idx/9/277/article/Adding_Manual_Control_to_your_19982000_Ford_Ranger _Pulse_Vacuum_Hubs.html
