97 deville "a/c shut off to prevent engine damage"
'97de'ville
09-27-2007, 06:11 PM
My father has a '97 deville 150,000 mi. + last week it started to run hotter than normal while driving to work being on road for approx. 10 min. or so a/c shut down with error message "air conditioner shut off to prevent engine damage". He noticed temp. up to 260 deg. kept driving at a steady speed moments later dropped back down to approx 217 deg. Then on way home did same thing. I removed radiator to have checked @ radiator shop says has excellent flow. Repaled water pump and t-stat. Still does same thing. cooling fans appear to be working properly. Possible temp. sending unit? Not that familliar w/ Chevy product. Does not appear to have head gasket problem. Am a Ford fan myself. I just don't want to keep throwing parts at it. Thanx for any input. To me seams to be flow prob. or sensor issue.
caddydaddy
09-27-2007, 08:40 PM
Since you have checked or replaced the major items, I'd look into a head gasket problem. NAPA sells a tester kit for around $50 that detects the hydrocarbons from exhaust gases that would indicate a bad head gasket. I've used it before and it's not too hard to do.
Also, I'd check that the water pump belt is ok, and not slipping.
kloebs
10-29-2007, 03:14 PM
Check the outside temperature (on the dash). My outside temp sensor went out and would not let a lot of stuff work. Should cost around $20 and is located directly in front of the radiator.
