2001 Grand Caravan Timing Belt/Chain Questions
mitachoo
09-26-2007, 02:09 PM
1) Does the 2001 GC have a timing belt or chain?
2) How frequently (if ever) should it be changed?
3) Are there any warning signs that it is about to go?
Stretch58
09-26-2007, 02:30 PM
If you have the 3.3 or 3.8 engine it has a chain. I don't think there is a time/mileage interval for it. There is a slack check that can be done to it that involves removing the timing case cover. In my opinion, if a person has to remove the cover anyway and it has 100k+ miles, I would put on a chain. I did the chain and water pump about 120K or so. Had the cover off for a leak anyway or I would not had done it. By the way, taking off the cover also involves pulling the oil pan, new crank seal etc. if it is done by procedure.
