91' light short
Serveck
09-25-2007, 12:09 PM
i have the most subborn problem that refuses to remain fixed for any good amount of time. and is apparently a fairly comon problem, but i have tried everything in those threads fuses #1 (back up lights/turn signals) and fuse #8 (instrument lights/tail lights/liscense lights) keep blowing fuses the second i turn them on, and now they refuse to work at all. i have: replaced turn signal relay (the clicker), dimmer switch (said it was a common cause) all the bulbs/ checked all the lines. it is shorting out somewhere but i cannot seem to find out where, the only thing that could be a cause that i have not tried yet is the multi function switch, but you have to pull the steering column out to do so. i have checked all the wiring diagrams in the haynes manual for the 87-91 civic and can still never find the cause, where should i check for wire shorts? this is really getting frustrating and i really need turn signals/tail lights, dash lights i can live without, but it is not legal on the road. this did not happen until hitting a pot hole and the fuse blew instantly leading me to believe something shorted out, but i cannot figure out where. any help would be greatly appreciated.
Christ
09-25-2007, 03:54 PM
all you have to do to get the switch out of the column is pull the steering wheel off, there are screws and maybe a cover plate right behind it, and once that is all gone, you have access to the two or three screws that hold the multi switch on.
