Question ...
ford460bigblock
09-23-2007, 04:59 PM
I got a 2002 mustang gt 4.6 2v its stock all around . 2 day I did a burnout I turned the track button off(as 2 disable the system) and then just powerbraked it(its an auto) only on tire left a mark it was still pretty sick lots of smoke and pissed off neibors but only one tire left a mark and I thought a v8 should make both tires leave a mark ?? Whats up this is ? Is only 1 tire spin or do both
neatofrito1618
09-23-2007, 11:38 PM
Sounds like you need to rebuild your T-loc.
ford460bigblock
09-24-2007, 06:48 PM
what other symptoms would there be cause i got no time to did it my self so i got to take it to ford amd am suree they will say no more warranties cause i did a burnout
denisond3
09-24-2007, 08:11 PM
In the days before ABS and limited-slip differentials, it was normal for the right rear wheel to do most all of the spinning. The torque of the rotating driveshaft to the rear axle tends to lift the curbside end of the rear axle, and to push down on the drivers side of the rear axle. To get both wheels to spin you needed to have a limited slip differential. Front wheel drive cars dont have this situation.
ford460bigblock
09-25-2007, 05:13 PM
thanks 2 day both spin and left marks + my rear diff fluild is new so am good
bugman742002
09-25-2007, 07:20 PM
to make sure that you have a limited slip diff lift the rear tires off the ground and spin one side if the other tire spins in the sam direction you have a limited slip if they spin in opposite directions you have an open diff.
ford460bigblock
09-26-2007, 02:42 PM
2 day i looked at the window sicker and it said that trac-loc was sanderd so i should have limited sip also it only spins the right tire when i do it with out using to much perssure on the gas but i get on it it spins both tires
6speed
09-27-2007, 08:37 AM
after a certain amount of miles you will be spinning one tire unless you rebuild or replace your trac-loc
bugman742002
09-27-2007, 05:04 PM
one thing i have learned since i started working at an auto parts store is that with out visually checking it is hard to tell what you have in your vehicle. we have people come in give us the right vehicle info and still get the wrong parts becase someone at the factory put the wrong part on it. just to day we had a customer buy a set of brake pads for a chrysler town and country with 4 wheel dics brakes. but the front pads were the wrong ones. it used the front pads for the one with rear drums. just because the build sheet says that it has trac loc doesn't mean that it does. i have seen a 93-94 camaro with an automatic with 3.42 gears and everything that i read said that all of the auto camaros had 3.08's in them.
ford460bigblock
09-27-2007, 08:12 PM
then i would have to look at the rpo codes but there not on the door or under the carpet in the turnk any ide were they would be alsp i nosed that if i start the car and just do a burn rightaway it spins one tire but if i drive like 1mile it burns both
bugman742002
09-27-2007, 09:40 PM
look at the axle tag. but an open diff will spin both tires if they have the same amount of traction. the easiest way to so raise the rear off the grond and spin the tires.
ford460bigblock
09-27-2007, 10:36 PM
so when i riz the car and spin the tires if its open they will spin in opiset rotation if its trac-lock they should spin in the same drirection
bugman742002
09-28-2007, 09:14 AM
yes that is correct.
ford460bigblock
09-28-2007, 02:49 PM
both spin in the same rotaion so i got at-loc
bugman742002
09-28-2007, 07:53 PM
yes you do. as far as the problem goes it just may be a automaitc trans thing.
neatofrito1618
09-29-2007, 01:34 AM
just because the build sheet says that it has trac loc doesn't mean that it does. Yes it does, 8.8's don't come with open differentials.
bugman742002
09-29-2007, 08:58 PM
so what you are saying is that my 93 4cyl has a trac loc in it since it has an 8.8 rear axle.
neatofrito1618
09-30-2007, 12:22 AM
so what you are saying is that my 93 4cyl has a trac loc in it since it has an 8.8 rear axle. 2002 8.8's don't come with an open differential, happy?
bugman742002
10-02-2007, 09:04 PM
i was hoping that it did because that would explain why i can't power brake it and spin the tires like i used to.
