brake issue
slikk
11-25-2002, 11:06 AM
dup great car heads .. i need possible solutions to this issue
my 91 lude has had the anti-breaking light light on for a while now ... what could be the fault of that .. also when i am speeding and i brake the car vibrated heavily .. what could be the reason 4 that
jusg19
11-25-2002, 02:06 PM
the vibrations you feel when you hit the brakes while going fast, it because your rotors are probably warped. mine were too, so i went and got the slotted rotors to keep them cooler.
the brake light, one thing thats the easiest to check is make sure you have enough brake fluid in the resivore, if you don't the light can come on. there are other reasons but this is the most common.
slikk
11-26-2002, 10:02 AM
more than likely itz the rotors then cuz the fliuid is the first thing i checked when the light came on ...
does anyone else have any other suggestion?
drift
11-26-2002, 05:19 PM
you need to go to the dealership to get the ABS light problem read. general ABS system malfunction, probably due to your warped rotors.
Prelewd
12-07-2002, 05:55 PM
Warped rotor is the main cause.. But it can also be caused by bent axle shafts, loose or worn wheel bearings or loose brake parts.
If you look at the brake rotor, you can usually see discolored patches, and that is a good sign that it's warped.
Like Jusg19 said, warping can be caused by excessive heat, possibly from riding your brakes, slamming them from stoplight to stoplight, ect.. but can also be caused by not torquing down your lug nuts to the right specs.
You can get your rotors resurfaced, but the problem could come back... Just get new rotors.
