2003 acccord v6 sedan ATF change
andresatp
09-10-2007, 12:20 AM
Wondering whats the best way to replace the ATF. Hanes says to do it through the dipstick...but its so narrow I cant find a funnel anywhere. The OEM manual has a diagram of a different bolt to refill but, it is not clear enough to me, so I cant find the damn thing... anyone have any ideas of what is the best way to replace the 3 quarts???????
Thanks in advance.
A
Thanks in advance.
A
wiseguy01
09-10-2007, 12:31 AM
go to autozone and get a black funnel maybe 5 bucks and refill through dipstick hole and make sure u shift through all the gears after u add 3 qts and then top off but the car has to be warmed up and make sure u use honda fluid dont listen to anyone the honda fluid does make a difference without the trans will hard shift... and it should take 6 qts for full drain and refill
andresatp
09-14-2007, 12:54 AM
Unfortunately no auto parts store makes a dipstick that is that narrow...the opening is about 1/4 inch....and I have tried about 10 places. how does the dealer replace it on a 2003 acccord??????????
wiseguy01
09-16-2007, 07:43 PM
u get a funnel with a hose on it like the kind they use to refill differentials in trucks some of them have a hand pump
