04 Rendezvous full brake pedal when SUV is off
rkolk
08-26-2007, 11:07 PM
Changed the brakes and front calipers on our 04 Rendezvous. Filled the calipers before connecting the brake lines. Bled the brakes with an assistant and with a hand vacuum bleeder. I can pump the brake to a full pedal with of compression with the engine off. When I start the SUV the pedal goes to the floor. I bled the rear first then the front, I have bled them several times at each wheel with no luck and the same results. Suggestions? :banghead:
