Cannot Adjust Power Mirrors
Uncle1957
08-20-2007, 11:50 AM
The second issue with my 2002 Montanna is I am unable to adjust either of the power mirrors.
There does not appear to be a fuse specific to the power mirrors.
Any ideas?
Thanks
Gord
GregA
08-21-2007, 09:52 PM
Hi Gord,
Check Fuse # 8 in the passenger side of the dash. Here is a picture, if that will help.
GM Minivan Fuses (http://www.my-chevy-venture.com/fuses.html)
Take Care,
catesja
08-21-2007, 11:48 PM
If your fuse is good, try wiggling your mirror back and forth. Mine every once in awhile will not make contact between the mirror and base for the unit to move. I have cleaned the contacts a little and seem to not have this problem right now.
Uncle1957
08-24-2007, 08:51 AM
Checked the fuse it is good... But the fit in the socket did seem sloppy.. Kinda like a loose tooth..... Mirrors still do not function.... How difficult is it to remove the fuse block to check there is continuity through the fuse. Seemed strange it felt sloppy. Then again it is the first car I have had that use the mini fuses.
So my expectations could be way out in left field.
Gord
