wheel well liners
nrizzo
08-17-2007, 07:53 PM
anyone know where i can get wheel well liners for the rear, on my 2004 2500hd. thanks
fillupread
08-17-2007, 09:40 PM
Rino liner! Not only is it awesome but it will lessen tire noise in the cab.
nrizzo
08-18-2007, 07:36 AM
i'm refering to the liners that are installed in the wheel well above the tires. they come stock in the frount but not the rear. thanks
fillupread
08-18-2007, 11:24 AM
Do you mean fender flares? The ones at the dealer will fit perfectly but they will cost you. Prob with generic aftermarket is that they usually need a little work to fit right. Your best option for aftermarket flares are from Bushwacker.
If you are actually talking about a plastic wheel well that goes INSIDE and above the tires I have no idea if those are even made. Maybe someone on here knows of a company.
nrizzo
08-18-2007, 12:30 PM
yes the one's under the wheel wells, a friend of mine bought them for his dodge. i found them for dodge and ford but not chevy....which is weird:banghead:
chuck16
08-19-2007, 03:11 PM
Isn't that because the fenders on the Chevy truck are just the parts of the box that aren't fitted with plastic. I don't have any fender inserts on mine. Maybe the new ones do, I haven't checked. But that does give me an idea. Why couldn't one rhino line the inside of their fender well to help wear and lessen the chance of rust and debris in there.
hmmm
'00Z71,5.3RcabLbed
08-21-2007, 07:50 PM
I don't think anyone makes them, I just sprayed mine with rubberized undercoating to get rid of the body color inside the fender well. Basically just for appearance. You may try to fit some from a Dodge or Ford though.
intel_guy
08-22-2007, 07:59 AM
Looking at the side profile of the truck, the wheel well profiles look very similar, but opposing. I believe the front right would fit the rear left and the front left would fit the rear right (with a little modification and drilling to mount them). Take one of the fronts off and try it in the opposite back side.
sub006
08-23-2007, 01:57 AM
Every time I look at the white (bed) over black (frame) rear wheelwells of my son's 04 Slilverado Z71 I want to spray in there with black rubbberized undercoating (worked well on my daughter's old BMW) or have it Rhino'd!
But he LIKES the two-tone "clash" and it's his truck so I have to leave it alone.
If you're doing this, be sure to paint the thin body color support rod that's also visible.
sc_customs
08-23-2007, 03:25 AM
You would probably have to go to the dealership on this one. I know a buddy of mine has rear fender well liners on his '01 gmc rcsb stepside. His came stock like that.
nrizzo
08-23-2007, 06:42 PM
can't find them anywhere dealer or after market
weo38
08-24-2007, 11:51 AM
A friend of a friend has them on his CC Silverado and he bought them from the aftermarket. He even found sealant the same color as his truck to seal around them. If I see him I will ask him where he found them. The fit was really good btw.
mbumgua
09-04-2007, 10:01 AM
My 2004 Yukon XL has plastic rear liners in wheelwell from factory--maybe those would work?
weo38
09-05-2007, 06:10 AM
I found out that my friend who has them on his truck used a set from a dodge pickup. He had to do a little trimming but they fit pretty well.
