96 CV hesitation/running rough and high pitch squeak at start
Cavibroke
08-15-2007, 02:07 PM
Alright, I have a 96 CV that I swapped an engine out of last week. The old one had a bad gasket and blew a hole in the block. After dropping in the “new” engine it has been running a rough when accelerating or just giving it gas. I pulled the codes which were PO171, PO174, PO151 and P1151. My brother also took it to a dealer and they said two of the O2’s weren’t working. However the car did run.
Now, after reading some of the post here I figured it might have been a dirty mass air sensor. So I checked the back two O2’s which were fine then I cleaned out the air sensor. After that I tried to start the car and it wouldn’t run more then a second. Once i unplugged the air sensor the car ran almost perfect. There was hardly and hesitation after that. So I bought a new air sensor thinking that was the problem only to find out it wasn’t. Plugged in the new one and the car still wouldn’t run more then a second. Unplugged it again and it ran fine. Also I wasn’t able to floor it prior to cleaning the sensor, it would just bog down and not accelerate.
Also there is a high pitch squeak that comes out from around the started when I start the car. I did tighten the starter down good so I know it’s not from being loose. Any help with either of these problems would be greatly appreciated.
Cavibroke
11-20-2010, 05:11 PM
Just an update. It ended up being the air flow sensor. Forgot it had to update O2's to run smoother. Also one starter bolt was still a bit loose.
