Power loss
rfsmith90
08-15-2007, 10:38 AM
ok i have a 92 firebird with a 3.1 v6 and my check engine light is on... it comes on after about 10 minutes of driving and then i begin to lose some major power... autozone hooked up their obd1 and found it to be a code 43- tps out of adjustment so i replaced the tps and i also cleaned the egr valve and cleaned the idle air sensor... the guy at advance auto parts said it just needed cleaned, but the autozone guy said it needed replaced... ideas?
wrightz28
08-16-2007, 09:33 AM
The TPS is adjustable, best at .52V.
rfsmith90
08-16-2007, 04:44 PM
im not sure about that, the autozone guy said it wasnt... i put a new one on just in case anyway... how do i go about adjusting it?
wrightz28
08-17-2007, 08:23 AM
You backprobe the ECM reference wire and ground, with the key in run, engine off.
rfsmith90
08-18-2007, 02:35 PM
ok sorry but that was pretty much over my head...
wrightz28
08-20-2007, 08:53 AM
OK, have a scanner that reads live data 'hooked up' so you can see the voltage form the TPS.
rfsmith90
08-22-2007, 12:36 PM
oh like an obd1 with a usb connector to a pc?
