1992 Honda Civic 1.5Ltr. - Irregular Idle
92CivicLX_PM
08-12-2007, 07:12 PM
I have recently replaced the following on my car.
Headgasket
PCV Valve
Distributor Cap
Router
Sparks Plugs x 4
Thermostat
Timing Belt
Now I have an irregular idle, the timinig belt was set to 30lbs. The Idle varies between 600 - 1500rpm.
Do you know what we are doing wrong and how we can fix the problem?:banghead:
Greenblurr93
08-13-2007, 09:21 AM
Vac. Leak, or clean the IACV.
orb666
08-30-2007, 08:40 AM
Pulldown your Throttle Body for cleaning. becareful in cleaning the side of the valve coz it has a gasket. be sure not to tear it off. also clean your air cleaner. if my suggestion doesn't help, adjust the timing belt if you have a Double Over Head Camshaft or DOHC engine, may your camshaft is out of timing.
SystemShock77
09-06-2007, 07:23 PM
Headgasket
PCV Valve
Distributor Cap
Router
Sparks Plugs x 4
Thermostat
Timing Belt
Could also be the TPS going out. Mine did that when my TPS quit working. I replaced it and every thing was fine.
