95 talon turbo awd are crank walks hard to install
bsskierfolife
08-07-2007, 09:25 PM
got a 95 talon turbo awd and i think its the crank walk but it could be the clutch master cylinder went bad are either of these hard to fix and are they pricey?
SilvrEclipse
08-07-2007, 11:16 PM
If its the master cylinder, then you replace that and bleed you clutch line. If you have crank walk you need a new motor.
Black99GST
08-07-2007, 11:31 PM
not for sure! but i would HOPE TO GOD that its the master cylinder... crank walk (cw) is NO FUN!
EDIT: Knock on wood!!!!
bsskierfolife
08-08-2007, 03:21 AM
but i have and extra crank cant i jsut put that on
inatalonIXLR8
08-08-2007, 07:41 AM
Sorry Dude. Not happening. If you want to sell PM me. I'm looking for one with a shot motor for my woman. Right now I've done this Talon Esi for her, but she wants to get a more serious ride.
http://i204.photobucket.com/albums/bb41/inatalonIXLR8/DSC01776.jpg
bsskierfolife
08-08-2007, 10:26 AM
so theirs no fixing it if its the crank walk.. it still drives fine though.
SilvrEclipse
08-08-2007, 10:36 AM
You would have to messure the end play in the crank to see if it was crank walk or not. If it has to much play in it then I would just drive it till it quits. You should go ahead and see if you can find a block to rebuild that way you could just drop it in with out much downtime. If you can do that kind of stuff.
bsskierfolife
08-08-2007, 10:44 AM
yeah im okay with that stuff but i also have a whole car club to help me im part of this club called twisted development. cause i have an extra crank i didnt know if i could change that and sand the fuck out of the wall.
bsskierfolife
08-08-2007, 10:47 AM
if not how much do u think i could get a block for my car.
inatalonIXLR8
08-08-2007, 10:49 AM
200-500
bsskierfolife
u think i could rebuildthe block now or if its that is their no rebuilding
SilvrEclipse
08-08-2007, 11:05 AM
I believe if you replaced the bearings, seals, and possibly the crank you would be fine. Crankwalk has to do with the bearing not the block.
bsskierfolife
08-08-2007, 11:24 AM
i got a crank but wat u think the seals and bearing gunna cost about 12 bucks a piece?
but thnx for the info
steviek
08-08-2007, 12:46 PM
man before we start go spending your money why don't you tell us what the symptoms are that you believe to be |CW.
bsskierfolife
08-08-2007, 01:10 PM
well i mean im not gunna go do it yet but i mean the clutch is feeling wierd and the problems are usually rare but i no sometimes its the crank walk but it could also be the clutch master cylinder
bsskierfolife
08-08-2007, 01:41 PM
forgot to mention installed a ACT 2600 performance clutch like 3 months ago
eclipse98gst
08-08-2007, 04:25 PM
Tell us Exactley what the clutch is doing!
steviek
08-08-2007, 05:05 PM
how many miles on the motor? What type of clutch is in there? Describe the Wierd feeling AND when it happens. Does anything happen when you make left turns? THese are the kinda things we need to know in order for you to help us help you.
bsskierfolife
08-08-2007, 08:29 PM
The carpet is wet with fluid from the clutch master cylinder and the peddle is never the same when you mash it. when the peddle is mush it is hard to shit but I just pump the peddle a few times and it is all good again.
SilvrEclipse
08-09-2007, 01:06 AM
If the carpet is wet then it is deff. the master cylinder
Black99GST
08-09-2007, 01:21 AM
:1: for master cylinder FOR SURE!!!
