94 Altima Blower Motor Problem or something else?
demotim00
08-06-2007, 06:44 PM
On my 94 Altima, I am having a problem with my blower motor or something else. The blower will only work on high, will not work on any other speed. Defrost, A/C, heat, bilevel & all still works, but regardless what setting it is on, it will not work on any speed except high. If I go to turn the speed down, it just shuts off all togather as if I turned the knob to the off selection. What could be wrong? How can I test it myself to see what the problem is?
Toolman5523
08-06-2007, 07:38 PM
blower motor resistor went south on you. it's right next to the blower, flat conn. about the size of a credit card. easy repair, and cheap.
demotim00
08-06-2007, 09:25 PM
Thanks for the info, I do have one more question. Is there anyway to test the resistor to see if its bad before replacing it?
Toolman5523
08-07-2007, 09:24 PM
just run a continuity test for each individual resistor. resistance should change for each speed represented. if you run across ol then you have found your break in the resistor.
demotim00
08-18-2007, 10:31 PM
Thanks alot Toolman. You were absolutely correct, it was the resistor. I didn't even know there was such a part. I was able to find the old in with nothing more than a mirror to see up under the dash, took it down, tested it, threw it out, bought a new one & put it back in. It took care of the problem. You managed to save me the $65 to have the local shop check it out for me & the $100 for the shop to replace it. Instead of costing over $150 if I would have had the shop check it out & replace it, I was able to do everything myself for nothign more than the cost of the resistor at $30.
