Dead Z-28
Golden Eagle 6573
07-30-2007, 07:38 PM
Hi,have a 81 Z-28 that quit on the road the other day.All indications its getting fuel.How do i test the Ignition coil and module?Car doesnt have a computer and has a 350 in it.thanks:banghead:
skibum1111
07-30-2007, 08:13 PM
Parts store should have a spark tester. It connects between the spark plug and the plug wire, flashes if you have spark. Hei ignition?
blindeyed
07-31-2007, 12:54 AM
Golden Eagle 6573 --- This thread has been moved to the "Problem Diagnosis" sub-forum. You can find these sub-forums listed at the top of the forum. When creating new threads, please create it under the appropriate sub-forum that your topic applies to. If no sub-forum has been created for your topic, then please continue to post threads of that kind on the main page. Thank You.
wrightz28
07-31-2007, 08:25 AM
Coil can be tested with an ohm meter. The module has to be tested with special equiptment, and make sure it is tested several times. If it comes up bad, replace with Ac/Delco, the extra cost is well worth it!
Golden Eagle 6573
07-31-2007, 07:24 PM
Thanks for all the input! I have bought a ignition tester and will try get this thing runningthis weekend.Car has a Crane high energy coil installed years ago,hopefully this is the problem.Thanks again.
Golden Eagle 6573
08-01-2007, 03:09 PM
Its alive!Problem was the wires feeding the super coil.Reattached wires to coil and it started right up.thanks again for the ideas.:lol:
wrightz28
08-02-2007, 01:20 PM
:disappoin
K.I.S.S.
:lol2:
