1992 LeSabre Custom Temperature Sending Unit
bjrobinson
07-27-2007, 01:48 PM
I have a 1992 Buick LeSabre Custom with the 3800 V6 engine. I am trying to locate the Coolant Temperature sending unit. I have found the coolant temperature sensor, but I need to know where the sending unit is. I bought a new one but I can't find the old one. I have a Haynes manual but it doesn't show the location. Please help!
spinne1
07-28-2007, 05:38 PM
Post a picture of it and I'll be able to tell you where it is.
HotZ28
07-28-2007, 06:25 PM
Driver side, upper engine, above transmission bell-housing, mounted in driver side end of intake manifold
bjrobinson
07-30-2007, 07:18 PM
Thanks HotZ28 but that is the Coolant Temperature SENSOR. I need the temperature sending unit. It looks almost the same but it only has one wire.
I can't figure out how to load a picture on here.
HotZ28
07-30-2007, 08:20 PM
OK, sorry about that! The one wire unit is located near the center, rear engine area, rear driver side of intake manifold, mounted in the block.
speedbullet2
11-03-2007, 12:10 AM
Ok i have the same problem finding this unit my car doesnt have a gauge at all im trying to add one can i get a picture if possible or link to one where this unit is suppose to be so i can add my aftermarket one thanks
HotZ28
11-03-2007, 02:27 PM
These pics are from my 94 LeSabre, & the same locations for the 92.
http://img104.imageshack.us/img104/1682/areaofdetailaw9.jpg
http://img114.imageshack.us/img114/821/rearblockctsok3.jpg
http://img402.imageshack.us/img402/5012/cts2wire1wiregi8.jpg
speedbullet2
11-03-2007, 04:53 PM
sweet i can check for that later the one wire one is for the idiot light and thats the one i belive i need to replace if you can take a few more pics on where the 1 wire one is located that would be awsome thanks so much for your time:smokin:
speedbullet2
11-03-2007, 08:56 PM
o i found it thanks for your help there was just a plug in the hole no sensor how lame is that lol anyways i need to get a fitting now to make my gauge sensor fit cause the one it came with is to large thanks again
HotZ28
11-03-2007, 09:07 PM
spinne1
11-04-2007, 12:35 AM
http://img66.imageshack.us/img66/2017/onewiresensorex4.jpg
My 92 does not have the "one wire" thingy in the picture. It has the coolent sensor under the throttle body but that's it near there. (unless I'm mistaken--it's from memory)
HotZ28
11-04-2007, 06:51 AM
Do you have a temp gage on the dash IC?
spinne1
11-04-2007, 07:43 AM
Well, I am going to stop being stupid and pull out my ESM.....Okay, it appears that I do have a gage, and that it is exactly where hotZ28 posted the pic about the one wire thingy. So I was wrong.
Well, I now just went out to look at my dash and under my hood. Despite what the ESM says, there is no one wire thingy there under my hood and there is no gage on the dash, just a red LED notice thing if the temp gets too high. The same on my wife's 92. She has a Limited and I have a Custom. This is weird because it is in the ESM so one of the two cars should have the gage, but they don't.
HotZ28
11-04-2007, 07:50 AM
The red "idiot" light, is controlled by the ECU when the temp exceeds (250 deg), IIRC. The one wire sensor, is for the IC gage only. :wink:
speedbullet2
11-05-2007, 03:45 AM
Yes on my 92 custom there was no sensor in where hot's is but there is a plug that screws in to prevent water from coming out the hole where the sensor whould be if so equiped im adding a aftermarket gauge to mine that came with a 1/2 inch fitting but the hole is 1/4 inch so i need to get a adapter and im set again thanks for the help it was right where that one wire sensor would be if equiped with a stock gauge
