pwr window replaced all of it...nothing
jul418
07-23-2007, 05:17 PM
...switchs and motor for the PS window and the darn thng still wont work... Now what???
acemech128
07-29-2007, 08:22 PM
which switch did you replace if you replaced passeneger side switch you must know rt window grounds through left switch so also check wiring from passenger side to drivers switch, also could have bad drivers side switch
'97ventureowner
07-29-2007, 09:58 PM
Welcome to AF. Have you checked to see if there is power coming to the switch on the driver's door?
jul418
07-29-2007, 10:08 PM
Replaced both switches
jul418
Havent checked that. Will do and reply
dj1111
08-02-2007, 07:47 PM
Do you have the wiring diagram for the vehicle? And a volt/ohm meter?
