1988 Sierra
rhamlin67
07-19-2007, 06:02 AM
I have a 1988 Sierra pick-up with an 8 cylinder 5.7L motor. White smoke comes from the exhaust when I accelerate. What's with the white smoke? Does it need a carburator adjustment, valve adjustment???
Rob
Rob
2000CAYukon
07-19-2007, 01:18 PM
White usually means water/coolant is being burned in the cylinders. That could be intake manifold gasket, head gasket or a cracked head/block.
Are you sure it is not blueish white? Which would be burning oil. Which would be rings or valve guides/seals.
//2000CAYukon
//2000CAYukon
