Low Compression in Cyl. 4 in my 97 Altima
chenzo26
07-17-2007, 01:10 PM
Whats up guys.
I recently removed my engine head to get it inspected since I had to stop driving it about a year ago because my fourth cylinder was pretty much dead. I had someone check the compression, and it was lower than 50. (psi I believe) Anyway, they were telling me that it was probably a burnt valve. I took the head off - which took some time - and looked at the valves on cyl 4, and everything look fine. I guess the other possiblity is that my piston ring on that cylinder is failling, but I am hoping that is not the case. Does anyone have any insight on how to diagnose this problem AFTER the head is removed. I know you can do a leak down test, but you have to have the engine assembled. :banghead: Any insight on other possible problems that cause low compression and how to diagnose them would be greatly appreciated.
Thanks,
Toolman5523
07-17-2007, 07:38 PM
You can pour oil into the cylinder, measure how high the level is. Then let it sit for a while and see how much leaks out. You can do roughly the same thing with the head, you might want to use solvent instead of oil.
RAREROD74
07-21-2007, 10:15 AM
you have to remove the valves to see if the seat is toast ....
