97 engine check light
q8alex
07-01-2007, 12:06 AM
say all how do i reset the engine check light on my 97 Q45 it over heated due to a loose radiator cap it's fixed but I dont know how to reset the light.
help Thanx
maxnix
07-05-2007, 01:52 PM
help Thanx
OBD II code reader.
q8alex
07-10-2007, 09:05 AM
OBD II code reader.
I thought there would be a switch or reset button is there no way to do it manually?:banghead:
maxnix
07-14-2007, 11:19 AM
Much easier with a scanner.
Read the FSM to do it manually. If you remove the ECU, you will probably see a reset button or a screw switch.
